SF5 Forester manual conversion- what gearboxes
I have a SF5 Forester STI Type II which is currently an automatic. I was wanting to know what gearboxes will fit. I have seen a WRX wagon for breaking that I can get most parts from.
My question is will a WRX gearbox be ok with the STI (EJ20) engine?
Forgive me I have tried to search but I have probably not been putting in the right term or phrase.
Hi, I've sort of replied in the new members section, but it's all good ☺ you'll need to get the gearbox code off the vin plate to at least work out what ratios it's running, would make life a lot easier if you could find a manual with the same ones as would involve less work in the long run
  • 2 months later...
Very sorry for the late reply. I had completely put this to the back of my mind but noticed the gearbox code today it is: tz1a3zb2aa-p5
Is there any sites to find what manual gearboxes run the same ratio.
  • 3 years later...
Have you converted  your car to a manual in the end?
