Rear boot strip
Does any one no how to remove this did a search can't find owt assuming it's a rear light out job but unsure 53b698d6c73c7f59175d873d7b4a71a0.jpg
Sent from my SM-G920F using Tapatalk
Hi Yes its an easy one had mine out a few time.
Open the boot and remove all the trim. It comes off from the top first just pull it towards you. Then the sides and at the last the bottom section.
You can then get a socket set into the back of the lights they have 3 bolts each. 2 on the sides and one in the middle.
You can then disconnect the bulbs and remove the lights.
Then its just about  8 bolts I think on the back of the trim part and 2 screws that where under the lights.
Everything also takes a little bit of a pull to remove the first time.
That should be it.
Also you will need to discount the cable for the boot release button.
This was typed from memory so might have missed something but its simple once you get the trim and lights out.
Nice one cheers for that soon as weather picks up I'll get it off n sprayed
Yup - thats it in a nutshell - be patient the first time you take the trim off particularly either side of the rear window - I managed to detach a couple of lugs on my last sharkeye  :rolleyes:
I'll make sure I take care with it be in new year before I get round to it
