impreza bushes
hi there does anyone no the standard anti roll bar size as I need to order new bushes but no sure of the correct size plus im going to change my rear shock does anyone have any good guides on how to do it my car is a 2003 impreza wrx
For the front or rear bar ?
aww sorry front and rear
finally made a start on changing rear shock got everything loosened of except the bottom bolt on the strut now this bolt is seized solid no even a impact gun can remove this looks like a trip to the garage to get it burnt off :angry:
Good ol red and blue spanner. Did you pre soak them in WD40? I done a rear hub a few weeks back and the 4 weeks leading up to the job I'd give all the nuts and bolts a squirt of WD. It made the job far too easy not a single seizure.
Boo, not thought about cutting it off ?
Thought I'd replied to your original message regarding the sizing, did you work it out in the end ?
