Wrx not starting
My 2001 wrx bugeye just cut out... Started to judder like I was in the wrong gear so pull into neutral n car stalled.... Car will now not resart... Checked timing belt n it's not snapped.... Any ideas??
Was like I was in 5th not 3rd
Nothing on ecu ether been scanned today
Could be cam sensor or crank sensor, but these would throw up a cel at least,
Start with the basics, fuel, spark and air. Make sure there's enough fuel in the car (sounds stupid I know). Check that you have a charge in the battery, and pressure at the fuel rail and work from there really.
Ok I'll have a look Tomorrow.... What best way to test spark etc and is there a way for testing to see if timing is correct??
I'd start with putting the back seats down and turning the key to the acc switch,that way you'll be able to hear the pump prime, (or not )
As for spark there are various diy testing methods on YouTube,
 Ive removed the pipe leaving the fuel filter n put the pipe into a bottle n cranked the engine to see if I had fuel..
I do have fuel lots of it but still no running scooby
  • 3 months later...
Thort I'd update this post....
Car had slipped on timing bending valves so I rebult engine using replacement heads etc and all new bolts n belts now back up n running
