offset issues
Right guys I'm after a bit of advice, I've seen the wheels I want for sale in the uk one set only and there's no more stock from th supplier. The wheels are 18 x 9.5 and to fit my car the recommended  offset on this size is 35 -40. The set available are offset 22 so will stick out further. If I went for these would I be able to get away with it or would the 13mm difference just give me a nightmare with clearance issues on the arch. There is plenty of room in the arch but I don't want a wheel that scrubs on hard cornering
They look pretty flush and I would have 13mm more poke 😕 cheers Geoff.  That does look good on 19's though
Yeah pitty, I assume they were a good deal. The air ride will be set for the picture but least you can use that fitment as a reference if you decide to keep looking :biggrin:
