wiring colours/diagram
Just having a poke around to see where to run the oil pressure gauge from, can anyone tell me whats what with the wiring ? All the loom under the dash has little grey spots on the various wiring. As well as a mix of colours. I was hoping for solid grey red yellow black etc
cheers,
from what i can see using my basic electrical knowledge i need to locate and tap into these top three and a ground then i'll be laughing,
12v constant, black/white to white  ignition harness
12v ignition wire  black to green     ignition harness
12v accessory wire black/blue to yellow  ignition harness
if i'm wrong someone please shout. i was gonna use the clock loom but i can't find where it disappears into the headliner which is annoying, i may just cut the clock wires at source and splice the gauge into it and run it back down the a pillar
