03 blobeye wrx gearbox question
Hi I'm fairly new to here so be gentle! I'm in need of a gearbox asap but can't get my head round what boxes will fit my car!
it currently has a TY754VN2AA
altough on the strut top the transmission type is TY754VN4AA
i just want to know what box I need or what will fit? And if anybody has anything suitable please contact me
thanks in advance
Goggle the ratio of your box ty number and the ty number on the strutt I'd plate . If they're the same ratio find a 5 speed box of the same ratio and it will fit fine fella 😉.
The only main differences between 5 speeds is the ratio (has to be the same as the rear diff) and the later (bugeye onwards) 5 speeds have a bigger /stronger casing than classic boxes .
Cheers mate, I have not done any of the upgrades on the car so I'm kinda lost with it!
the cars a cracker and it's my fault it's broken lol I just don't want to get the wrong box just want it fixed now!
Cheers
Yeah "scooby" should be a reconised language of it's own but you'll soon get used to the jargon. Basically any 5 speed will mechanically fit. So if you get a bugeye onward box with the same ratio as your existing rear diff it will drop straight in . I'd also consider fitting a clutch while it's out ,cos you'll be gutted if the clutch goes shortly afterwards as the box will have to come out again [emoji6]
100% putting a clutch in it had started to slip under hard boost a bit and had a high bite!
