No idea where does it go ? Have you chased it back ?
Where abouts it's that pic taken of. I looked on my 03 sti and can't find that plug.
Both my 97 UK turbo and the v1sti have this plug but neither of them had anything plugged into it . The v1sti did have the tmic water spray as standard but the tmic spray set up was in the boot when my brv bought it (cos it had a fmic fitted) .
I vaguely remember the water spray system had a white round plug .Maybe someone has a standard classic sti with the water spray system still operational and can confirm if that's what it's for but I'm 80 % sure that's what it's for [emoji6]
the attached pic is of a 03 wrx sti type uk prodrive stock with standard IC Sray. is that the area you were after ?
Yeah neither can I. Il be getting my classic forester back on Friday il see if there is any plug there.
OK, not sure on v1-2, but where is your redundant cat over heat sensor taped up to ? location of your round one is in the same position as mine but mine is a slightly different shape
V1 /v2 o2 sensor is in the headers just before the upipe. They moved it to the downpipe from v3 onwards [emoji6]
