Hose
I'm trying to remove my intake resonator on my V2, and so I bought a delete pipe. Unfortunately, as well as having three inputs instead of the two my box has got, it's about 3 inches short!  Anyway, I've put a screw in one of the ports to seal it off, and I've used an old offcut hardpipe to extend it with a silicone joiner. The only trouble is, the hose from the bottom of the boost solenoid is now too short! Does anyone know where I can get some? I'm needing about an extra 2 inches on top of what's there already. So about 8 or 10 inches.
If you're proppa stuck and need to get it back together. ... the window washer tube is the same diameter (so you could use that until you get some new stuff ).
As for buying it I normally get my generic silicone hoses from "ash"
(Auto Silicone Hoses) but there's loads of companies like boost junkies that sell vac line kits on ebay
Cheers Savage. I just put the resonator back in until I can get some. I'll check ash out later.
Purchased one metre of 6mm internal diameter silicone pipe from ASH at the vast cost of £1.80 Inc postage.  Why can't all mods and bits be that cheap! Cheers!
