What Is the average cylinder compression results for a Impreza uk turbo 2000 with 100.000 miles ?
Cold test on an engine I have is:
1...125 psi
3...115 psi
2...140 psi
4...140 psi
They all seem a bit low to me and cylinder 3 looks really low, probably below 8 bar.
I did a test a few weeks ago using another tester but it has now been binned because it was giving faulty reading on a few cars.
Took me ages to work out how to upload a video of the sound my engine is making. My kids say its because Im getting old :)
But Listen to the engine tone when holding it at 2500 rpm. It does not sound proper to me
I don't know the answer off the top of my head but did some googling as I'm working night shift (hee haw else to do!) and it seems a normal pressure is somewhere in the high 130's to 140's and all the cylinders should be within in around 7 - 10psi of each other. So I would say cylinders 1 & 3 are def down on compression.
So maybe the start of a head gasket on its way out?
Thats what I did not want to hear. Mind you If the engine has to come out then under bonnet is getting a good clean up and all things painted.
Cheers Sandals :wink:
Sorry to be the bearer of bad news! Fingers crossed i'm wrong... but since it's the two cylinders on the drivers side, head gasket would make sense :(
Its more about balance across the cylinders rather than how high. Doesn't look great with 1 and 3 being down, 3 looks pretty poor result
I think its best to pull the engine and do a rebuild. I should have done this a couple of years ago but I became unwell and garaged the car. Now I am fighting fit the car is getting sorted properly, It will be a modern classic by the time I have finished it lol.:rolleyes:
I will probably do the build topic when I have the time because I have loads of photos of the old scoob with all the work I am doing, Its just not a cheap car to work on so It takes a bit of time.
I already have the rear bumper off and the bar that is supposed to hold it on is rotten so I need to source out that, then a couple of small repairs to the rear sills and rear arches. Cut out and replace then wax oil.
Tidgy do you hear anything wrong with the engine through exhaust ?
Sound wont tell you much i'm afraid, unless its running really crap and spluttering.
