Knock sensor
My knock sensor is still retarding my timeing by 6 degrees but only now and again
I'm running on 99 fual
It has a new knock sensor
There are no air leaks
It's had new plugs
It's got the old to new coils on
Just had an oil change
Help
6 degrees isn't much and I wouldn't be that worried, mine typically pulls 2-3 degrees and that's with all new engine, gearbox mounts & pitch stop so maybe it's just picking up background noise too ?
I will try and change them it just seems it pulls down the power a lot
Have you reset the ecu since you changed the sensor ?
yes
one thing i an still confused about is why it only happens now and again
How's the 02 sensor ?
sorry new universal one of them as well (forgot that)
