How many lambda sensors in 2000-2005 models?
ok thank you! Well the price looks very good, also they're stiffer than standard (according to their customer service) so that's great for fast driving, but not that great for off-roading...
On 9/5/2016 at 9:24 AM, stants said:
Pedders do loads of different parts, you can get lowering kits/raiding kits comfort etc
My suspension was dead the shock wouldn't return under its own power the only thing that was doing any work were the springs, so can't really compare, the only other scoobs I've ridden in have been on coil overs
How does your suspension perform in terms of COMFORT on BAD roads? Does the car jump like on the coilovers. do you have feeling like you're sitting on the bench when driving?
The car is fairly stable &planted, never really get any jumping, soaks up bumps well on 'soft road' excursions like farm tracks/ rutted fields
OK I'll go for this suspension as well then -) Did you get just the standard suspension or their improved version? Also do you have shocks at the rear separate from the springs or both at the same time like in Front?
http://www.pedders.co.uk/subaru-forester-sf-ezifit-front-suspension-kit_p31236863.htm
http://www.pedders.co.uk/subaru-forester-sf-ezifit-rear-conversion-kit_p31236862.htm
I went for a front and rear 'kit' as all 4 were shot
so the same kits as on the links provided?
