Rear sub frame
Hi first time on forum. I have a forester 2000 model 2.0. Needing a rear subframe for mot
someone suggested to me that the Impreza classic has same sub frame ?
Would this sound correct.
Cheers. Charlie.
they do cross fit with many impreza early models so is a good way source a sensible priced used one .
If small areas of heavy rot they very easy repair to high standard, removing them means want new bushes and bolts more than likely, couple we done turned into bigger job with rot on chassis deal with & mount captive fittings needing fabricating and welding in .
heavily seized bolts in lateral links can up cost of job too .
Many thanks got 1 from Impreza parts co.
And arms so getting all bolts required from local Subaru garage. Bushes seem in good condition.
Will take advice on anything else that will make refit easier.
Cheers.   C
Just to say thanks. Impreza classic rear sub fram is perfect for forester.  And got new arms also. These are round instead of Chanel ones so even better.  All from .  Japperformanceparts. Great service.
Thanks again.
