Fuel leak!!!
Hi there guys, just want to say was a good japshow good day out so thanks all! Hope youre all well!  i put the car up on the ramp and i find a fuel leak! Parts of the fuel tank is pretty much rusted. I find when i fill up more than a quater tank that is when it leaks and the leak travels down and drips off really quickly. Once its about a quater tank it stops. I basically need a new tank and another new pipe with the clippings. Can anyone please help me in terms of advice or help me locate the parts and i will purchase them. Tbh the mechanic showed me it was the two pipes in the pictures. Please help me!
So the big bendy pipe which is rusted is what it is dripping down then i need the little bendy pipe inside as well, please help
Impartsb46 on eBay usually has them for about 75quid,
Failing that I don't think they are much more than that from subaru
Thanks stants will take a look. Is it the actual fuel tank then? Im dazzled
It's your fuel filler neck, a common problem, that bit attaches onto a rubber flexible pipe which joins it and the tank,
