3 port boost solenoid on classic
As above is it an upgrade or any advantages if its possible to fit a 3 port instead of the 2 port that is fitted to my car at the moment
3 port gives the mapper better control over the boost targets, so yes it's a upgrade.
But it has to be mapped in /calibrated straight away for it to work ,so is best fitted just before mapping or by the mapper
Ok cheers for that the car is getting mapped at the end of January so I will get them to fit it then thanks
Yes it was but I got one from east kent subaru's in the end and it worked a treat
All iv got to get is the ngk plugs for it to run perfect but I will have that from you next week if that's ok coz money is tight at the moment but are they easy to plumb in
