Cv axle problems
Need help. Trying to get my driver side cv axle out. It will not for the life of me punch out. What's a good way to punch it out?
Try heating the hub. Otherwise soak with PlusGas and put a big 3-leg puller on it.
I'd go for the puller and i bit of heat too
Sent from my LAUDE S500 using Tapatalk
Yeah a bit of heat and a puller should do it but if not see if you can get a local engineers or fabrication workshop with a hydraulic press to press it out i've seen some shafts take 10-20 tonne of pressure to get them out, they can get quite a hold if they've not been out for a while or indeed never been out at all :biggrin:
