XXR 527 18" 8.75 5x100/114.3 ???
I was thinking to treat myself for Christmas to buy XXR 527 18" 8.75 5x100/114.3 but i been told wheels to wide for my subaru impreza wrx 2006?
Not if you fit some arch flares [emoji6]
What about inner of the wheel not going to rub???
As long as you get right off set for your car then will just stick out more.its the off set you need the same as wheels you have on allready.
By my wheels now 17" but i don't now about off set on this wheels!But i been told off set can't be bigger then 8.50!!!But wheels i what to buy 8.75!!
Thats not offset mate that widness of the wheel look on inside your wheel will say et50 or some number thats of set
You can fit 9" wide wheels with arch flares fitted
Ok great i will double check before i buy thanks for info! :)
I just check on wheel i what to buy is et20 now i need to find out wheels i have on my car 😂
Am not sure but sure someone will say the right et, but i think et20 is wrong for your car
I have a hatchback wrx and i have just treated it to some 18 by 8" prodrive alloys and et on them is et50.my original are 17 buy 7.5" et50 so will stick out more.i need to put arch flares on mine when i finally want to put new wheels on after winter 24b20b1ab52f0c1eca758033fdfe4b59.jpg
World rally blue.all my other scoobys have been silver and 1 green.always wanted the blue.
Good choice i what blue is well but silver come for good price what i both silver 😊
Offset is relative to width of Rim. An 8" wheel with et50 will not be the same as 7" wheel on et50. The offset is the measurement from the centre of the wheel to the face that bolts to the hub.
Et50 on a 7"(177mm)Rim leaves you with 138.5mm back of the hub towards strut and 38.5mm stick out from the hub towards the edge of wing. 8" (203mm) would be 151.5mm towards the strut and 51.5mm away from hub. Offsets are always awkward and confusing.
Thanks for info! ;) I think i found correct wheels but there only 17" 8.25 et35!
Good place to check your new setup is here: http://www.willtheyfit.com/  I have XXR527s 18x8.75 ET20 on my wagon with 15mm spacers, my friend has 18x9.75 ET20 also on a wagon, we both have flares. I don't think its possible to fit them without. Maybe 8.75 ET35 on a saloon with rolled arches and a bit of camber.
Xxr are a cheap alloy , expect issues / bent rims
Yes, if you keep driving in to curbs or flying over pot holes ;) Wheel on the pic took straight hit from another car that bent my wishbone. Not bent, not cracked, just some normal damage.
same wheel nuts as i have just got and similar wheels but mine are the prodrive wheel.
2 people I know put big flat spots in them and wheel place won't weld them !
wont touch rota either apparently
Looks like xxr527 not good at all.But priblem is there look nice 😁after this comments i'm not sure if i what to buy.Any body now any good wheels?
