Geordie444 Posted January 22, 2017 Posted January 22, 2017 Hi all.. new to the forum as recently purchased my first scoobie.. I got a 2006 legacy 2.0r .. my gear box has a grainching to it so looking to swap it out.. now the gearbox code on my arch is TY757XTCAB and I have found one with TY757XVCAB now I have looked everywhere on every possible chart to see if they compatible or what not but nothing so hoping you guys could help me? Thanks in advance :-)
savage bulldogs Posted January 22, 2017 Posted January 22, 2017 Hopefully one of the legacy or sport boys will know about the n/a legacy boxes . Throughout the impreza turbo range ,well from 92 to to about 07 , all manual 5 speed boxes are compatible with any rear diff of the same ratio . Even the later sti 6 speed box will work with any 5 speed diff of the same ratio as the 6 speed box . So I'd imagine, if the ratio is the same that, they would be compatible but I don't know for sure and don't want you to buy it without someone else confirming it . As I've never seen either of those codes before ,or a legacy gearbox for that matter . Best of luck getting it sorted
Geordie444 Posted January 23, 2017 Author Posted January 23, 2017 Thanks for the reply. I have looked on all the charts and cannot find neither of these 2 codes... so I don't know what ratios etc... quite frustrating tbh. Thanks for the help
stants Posted January 23, 2017 Posted January 23, 2017 http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru%20Transmission%20Chart Have you had a look at this Sent from my SM-G930F using Tapatalk
Geordie444 Posted January 23, 2017 Author Posted January 23, 2017 Hey mate ... yes I have trolled the Web looked at every single chart possible. . Getting on my tats now...
savage bulldogs Posted January 23, 2017 Posted January 23, 2017 What about using the model code to see if that turns up any info about what ratio box it should have ?
