Rear light wiring
Hi all managed to get some sti rear light yesterday for my classic but after fitting noticed some problems passenger side is fine but drivers side indicator is very dull and slow lights fine but when I press the break the light goes dull and indicator comes on I'm thinking it's wiring problem does anyone have wiring diagram thanks5552ce293dd57b6f11e1b422a5bc8424.jpg
Check your earths that's what usually happens with a poor earth.
Ok mate I'll check that first thanks
And you have the right wattage/type of bulbs in there if you have one wrong can play havoc
Sorted it 2 wires that went into the plug wasn't connected to anything on other side so swapped the pins now all working fine :) thanks guys
