Nwge1234 Posted March 27, 2017 Posted March 27, 2017 I changed the oil yesterday and noticed a green stain around the oil cooler. I'm assuming the cooler contains copper and I'm seeing the green copper corrosion. As far as I know that doesn't happen with oil! The two coolant hoses seems well attached, and the green (corrosion?) is higher up than them anyway. A few ideas: - It's an oil leak and turning green for some reason -> change the oil cooler seal. Easiest fix, but I doubt it's that. - The oil cooler itself is leaking water from somewhere, maybe through the walls/tubes to the external surface. No idea... replace cooler. $$$ - There's a water leak higher up, but I couldn't see anything like that all. Any ideas? - It's water splashed up from the road. I can hope, but I don't think it's this one unfortunately. Happy to be proven wrong! I've had the car just over half a year. I changed the coolant soon after getting it and it wasn't clean, but didn't look tooo bad. There are a few different leaks around the place, and I should've been suspicous of the overly clean engine bay when I looked at it. Too late now! Any ideas about this one would be very welcome. I've read loads of threads about oil leaks from the oil cooler, but haven't seen any about water leaks. Thanks. Oh yeh, I was worried about the head gasket leaking coolant, but it looks reasonably clean around there. I tried to catch it in the photo so you could see it, so any thoughts about that would be appreciated too.
kayzarh Posted April 5, 2017 Posted April 5, 2017 Check the oil to see if it's contaminated. I've never seen a water leak go green to be fair, it's usually Whitey limescale. I'd say clean it up, check the oil (or do a service) You could also check the oil filter for traces of coolant. If water ain't mixing with oil, and oil or water levels arnt changing then it really can't be anything serious!
kayzarh Posted April 5, 2017 Posted April 5, 2017 You could also check/nip the upper radiator hose as when i had a leak there coolant got all over the bottom of the engine!
kayzarh Posted April 5, 2017 Posted April 5, 2017 Mayaswell take the modine off and inspect it for flat or birttle seals
Nwge1234 Posted April 12, 2017 Author Posted April 12, 2017 Hi, thanks for your ideas. I've been over all the hoses I can get to and replaced the clips on them - no noticable leaks either when the engine is running, or when I've pressurised it with air to 20psi. I changed the oil a few weeks ago (when I first noticed this) and didn't see any coolant in it at all. I've still got it so I might put it back into a tray and see if it separates out at all. As per my other thread, the next step is disassembling bits and flushing etc, and the modine will be on that list of things to do. Thanks!
Tidgy Posted April 12, 2017 Posted April 12, 2017 Modine is an oil to water heat exchanger. I would suspect the water side has a leak, or did if its not fresh. The green could just be the antifreeze adative in the coolant dried up. Thats all a guess but seems logical
