Cambelt & water pump change
Hey peeps
ive ordered a cambelt & water pump kit & ive been advised to get some coolant as this will be flushed when its changed... im looking for a pointer on the coolant side of things please.
first of all how much cooant do i need to fill the system?
secondly... is the suitable for a 2005 wrx - http://www.ebay.co.uk/itm/like/Comma-Super-Longlife-Red-Concentrated-Antifreeze-Coolant-5L-SLA5L-5-Year-Life/371310592373?hlpht=true&ops=true&viphx=1&_trksid=p5197.c100068.m2280&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140211130857%26meid%3D8469accdec51472e8955af73216239b2%26pid%3D100068%26rk%3D1%26rkt%3D6%26sd%3D191988066324%26clkid%3D4162803640545540644&_qi=RTM2063753
ive looked for a sticky on this but couldn't find one
thanks
Balls just written a massive reply and lost it.
Basically the comma stuff will be ok, i had it in mine for three years with no problems,
make sure you flush the old stuff out in case it's had a different type in, the two will react and turn to jelly 😲 just take off the bottom rad hose and pop a hose pipe in the radiator and header tank and run it for a while,
I think it's about 5L you'll need I just did a 50/50 mix concentrate & de ionised water
thanks fr the reply Stants - much appreicated.
