Wanted - Whiteline 24mm Rear Anti Roll Bar for classic impreza
Wanted, impreza gc8 (Classic) Rear whiteline 24mm adjustable anti roll bar
I have a 22mm rear bar if your interested?
Thanks for the reply  but I've got a 22mm adjustable front one to go on aswell, so really need the 24mm rear to complement it.
Fair do's you doing any track work ? 22 on the front for a road car is very stiff even with a 24 on the back,
I'd recommend uprating the mounts on the rear if you go that thick
Probably won't be doing the track but want to get it as good as possible in case I do!  Thanks for the tip, I was thinking of beefing up the rear mounts by modifying the bracket so it fastens by a bolt either side of the bushes.
