Coolant
Hi guys . Does anyone know how much coolant I will need to do a change , and what coolant are you guys using ? I know it's got to be oat coolant , I've got a coolant leak and I've just been topping it up for over a year now with Halfords pink stuff , but I've got new hoses to fix it now so want to put something good in , is buying concentrate ok I'm a bit sceptical mixing with water , but concentrate is considerably cheaper . Any help would be great
Ant oat will be fine just do a 50/50 mix with distilled water
I got advised Motul Inugel Optimal as a top of line coolant that is compatible with subaru's picky coolant choices, the capacity is supposed to be 7 litres so I got 2x5 litres to have a bit spare and it's done fine so far. It's all premixed too so just flush out the old and poor it straight in.
http://www.opieoils.co.uk/p-903-motul-inugel-optimal-car-antifreeze-coolant-ready-to-use.aspx
Yes I've got that in my basket as we speak it looked the best haha , 7ltrs !! Good job I asked I was only going to buy 5ltrs [emoji85] thanks guys .
