Fuel Filter Part Confusion! HELP
Heya. Need to change my fuel filter but having problems locating the correct part.
All the ones I've looked at on the net have the fuel filter by the nearside front strut top, but mine doesn't. I am assuming it is in the fuel tank but I want to be sure before I buy the part as theyre a bit pricey.
I have a 2007 2 litre non-turbo impreza.
Thanks for any help in advance, Zoe
Yeah it's in the fuel tank. I've never changed mine because of where it is. Let me know where you get the part from and how you get on fitting it! I'll maybe have a go myself...
Yeah it's in the fuel tank. You're thinking of the fuel pressure regulator? It's easy to do, just a bit of a pain to get it out as the hole is small. Just be careful not to bend the float arm. If you need help I can probably help. Takes a screwdriver, 8mm and some pliers. Maybe a hour or so max? Just make sure you disconnect the battery before doing it as well 😊
