Fuel filler neck pipe
Need a new fuel filler neck pipe for my 97 legacy can any one help im in the UK also
Sent from my thl T9 Pro using Tapatalk
Impirt car parts should be able to sort you out
Is that import car
Lol OK thanks. Any one know why my ac ain't working just had it tested for leaks that's clear and had it refilled but compressor don't fire up
Have you tested to see if it's got power to the plug ?
Could possibly have had the fuse pulled if the previous owner had disconnected it ?
Can't really help too much, as my aircon pump ,rad and pipework was 1 of the first things I removed on my 94 sti
Is your leggy a wagon or saloon ?
Its the wagon
