Bonnet Louvres/Vents Aero
For sale KJB Fabrications Bonnet Louvres.
-The product will come flat as seen and is designed to be bent by hand. You are able to bend the vents to the angle you wish although advised between 30° and 40°.
-The design incorporates a built in gurney flap at the front of each panel which sits at 90°, You are then able to bend the vents to the angle you wish although advised between 30° and 40°.
-Designed to relieve high pressure under the engine bay.
-Wick away hot air from the engine resulting in dramatically lower operating temperatures.
-Made from Stainless Steel and supplied with a fitting kit that includes M5x0.8 button head screws, M5x0.8 nyloc nuts and rubber U-strip to finish off the aperture when cut.
-Some of our customers choose to powder coat or paint their new louvres.
-Designed and made in the UK.
Any questions please get in contact.
Price for 2 piece kit £140
Price for 3 piece kit £180
@rps next mod for her?
Most likely wheels and arches will be next
  • 3 years later...
