Jacking points
I have a GR 2010 sti hatch and I am unsure where the jacking points are? The diff is not an option cause I only have a short jack
Their is a thread allready for this mate.with a picture for jackin points and axle stand positions.but if your using oem jack then its front and rear corners under side skirts
Hi mate I have looked at the picture but if it is the same one then I can't make other where they are.
Their about 8 inch from each end.not best picture as my car is lowered so hard to get under.but its this cut out a1aa232b4cfaaf3677d70df9e3ebb621.jpg
Is that where I would put a trolly jack?
I wouldnt put trolly jack on their will push skirt up.can you see that triangle plate in background in picture can put trolly jack on that for front.i go take a picture of back for yeah
Carnt see with how my car is park.but you sould be able to reach rear diff easy from rear car with a trolly jack.its were i use to lift both side at once.if i only want to lift one side i use oem jack on skirt lifting points
You could lift from skirt jackin point with trolly jack just go slow at first to make sure car is liftin n not bending.best to lift from their if you get one them rubber hockey puck pads for jack.
That is my worry. Cheers mate j will have a look tonight
