Knocking noise when releasing clutch to move off
Hello again everyone,
I was wondering if you could assist me in figuring out the source of a knocking noise and what could possibly be causing it. :mellow:
I have a 2006 impreza 1.5 R, when I am releasing the clutch to move off from a stand still a knocking noise appears, as though the engine is tapping something in the bay.
I haven't been able to pinpoint the problem and recreate it everytime without fail. But if I am pulling off from a stand still then the noise could happen once quite loudly or 2 or 3 times consecutively but rather quiet. :huh:
I usually move off at around 1,500 - 2,500 rpm (tis a baby 1.5 :tongue: )
Dropping the clutch or doing my best to make the car jerk back and forth does not seem to produce the noise so I'm a tad confused to the analogy of a loose engine.
As odd an explanation as this is, would anyone have any insight as to a common problem associated with such a noise? :smile:
thank you
  • 8 months later...
I guess if anyone ever finds this, here was the solution. The engine mount behind the engine connected to the firewall was a tad loose. The bolt that squeezes it together wasn't tightened properly.
