N1ckhe4d Posted January 29, 2018 Posted January 29, 2018 A few days ago my awd warning light came on and the diff screen vanished. Then came back on and all was fine. But over the past 4 days it still does it once in a while. Does anyone know why it could be doing it? I've had new tyres fitted recently with the recommended Dunlop RT and the pressure is exactly what it should be.
david1972 Posted January 29, 2018 Posted January 29, 2018 There's an owner up here having the same problem, but they've just changed their tyres all round to rainsport 3's - they won't be happy to hear of the issue with a set of new Dunlops as that is what the dealer is claiming is the problem with theirs (different tyre brand)
N1ckhe4d Posted January 29, 2018 Author Posted January 29, 2018 @david1972 Yeah that'll be annoying. Can you remember his name? I can't find the post.
david1972 Posted January 30, 2018 Posted January 30, 2018 Post isn't on here. Did some asking round last night and it appears to be a known issue - the DCCD control unit needs replacing: 1
N1ckhe4d Posted January 30, 2018 Author Posted January 30, 2018 @david1972 Seeing as mine is still under warranty, does this mean it should be changed by the subaru dealer who sold it to me?
N1ckhe4d Posted January 30, 2018 Author Posted January 30, 2018 @david1972 Thanks for your help mate. It has actually sorted itself out but I'll be questioning them about it. What I've noticed is that with the new wrx sti, it takes a while to register anything new. Even when you put fuel in. Even when the tyre pressure warning come on, and then you top them up, it still takes a while to recognise normal pressure.
ScoobyDude Posted February 1, 2018 Posted February 1, 2018 On 30/01/2018 at 8:24 PM, N1ckhe4d said: Even when the tyre pressure warning come on, and then you top them up, it still takes a while to recognise normal pressure. I've just had my TPMS light come on, Tuesday, refilled (4 psi down, left rear) and reset the sensors using the reset button. Right side by the traction button. Currently running Michelin Crossclimate all round, different size to stock (235/45) and set at 33 front/30 rear, and I'm not having any problems. Glad you're sorted now. 😁
N1ckhe4d Posted February 1, 2018 Author Posted February 1, 2018 @Pixyflash When I press the tyre pressure button. It gives me tpms1 and Tpms2. So how do you reset it?
ScoobyDude Posted February 1, 2018 Posted February 1, 2018 😂🤣😂 Think I may have conned myself!? Refilled the tire, and cuz someone was waiting I drove round the corner and stopped, pressed the tpms button, got what you have, tpms1, and kept my finger on it. Fairly sure the display told me it had reset... amd the light went off. Now you've got me wondering if it was just well timed? Gonna have to Google now. Post if you find anything, I will.
ScoobyDude Posted February 1, 2018 Posted February 1, 2018 Ok, if I've got this right, this is how it works. There are either 2 or 3 tpms settings, depending on age and model, I think we've just Iot the first 2. 1, Ordinary 2, Loaded (with passengers) 3, Towing Press the tpms button till it cycles to what you want, and hold for approx 3 seconds, that'll set it for that loading. You can set it to monitor your pressure depending on who or what's in the car. 😁 1
N1ckhe4d Posted February 2, 2018 Author Posted February 2, 2018 @Pixyflash Yeah I only have the 2 settings. Not the tow settings, which I'm not bothered about. I spoke to subaru and if you have all 4 tyres exactly the same. And the awd warning light keeps coming on, then that's when they need to change the DCCD controller because its too sensitive. As @david1972 posted. Changing to a different set of tyres that aren't the recommended dunlops, shouldn't cause the AWD warning to come on.
