Odd noise during pulling away
Hi,
noticed something new today. When I pull away or stuck in a jam and drive really slow in 1st gear, I hear a somewhat pitching sound. It’s not the brakes, I checked and it disappears when increasing speed. Don’t hear it when in neutral either. Best guess is the transmission?
Any thoughts?
probably take it to the dealer tomorrow just to check before a holiday drive...
On 27/03/2018 at 6:19 PM, marcothio said:
Hi,
Any thoughts?
Probably Its the thrust bearing, loads do it, if you let the clutch up and down without ebgaging it you can even play a tune. Mine does it occassionally but usually only when cold
