1998/99 GC8 ABS Issues
Hi hope everyone is good.
1998/99 Uk 2000 Abs light suddenly came on a few weeks back, i noticed the pump was silent ( it had been sounding a bit ropey lately) so i changed the abs pump.
Changed brake fluid for fresh bled the calipers cleaned the sensors. Pump sounds good now so assuming it’s working fine
My ABS light is still on, is there a set way to turn it off) ? i have googled it but can’t find a definitive answer) tried pulling battery & pulling fuse to no avail
Id be grateful if anyone could help on how to reset the abs light.
Theres a how 2 sticky thread in the tech section on here that shows how 2 self read ecu codes and reset the ecu .
If it's still on after that check the abs rings on the hubs aren't cracked , sensors are clean and abs sensor wiring plugs are making a good connection
Thanks Savage 👊
