Outback SS or 55 error code
Hi.
I have recently bought a 2004 3L outback. and so far really like the car.
But it has started getting a SS or 55 error code with the traction abs lights coming on.
It used to happen after driving for about an hour. then was coming on earlier. Now its as soon as I start the car before even driving.
I have read that its most likely a abs sensor fault. I have measured the resistance for the front sensors and they both read 29.26M ohms and 29.50M ohms.
A friend of mine also has the same car so we measured his sensors and they were 22.6M ohms on both front sides.
could someone tell me what sort of reading I should be getting and if the reading I have are within tolerance.
I will also test the rear sensors when I find the connectors. But have not been able to locate them yet.
