Running lean on wot
I have attsched photo of the log that i just did and this is the problem.
When i try to push the car it runs lean something like 16-17 afr than start to be rich again.sometimes it stays lean all over the way to red line.
i tried to flash the original map of the car same problem, it looks like the close loop dosn't change to open loop or i have boost leake or vacum leak.
Please your opinion.
I have:
TBX
Big TMIC
3 port ebcs
Wallbro 255 FP
K&N oem box air filter
Sent from my SM-G955F using Tapatalk
