Uprated Injectors
Hi,
im looking for some pink 550 or larger injectors for v3/4 97 type r, if anyone has any for sale or know where to get them.
The biggest side feed injectors Subaru make are 440cc's they tend to max at 340hp , which is about the limit for the standard classic gearbox .
Most tend to go for a "top feed " injector rail conversion ,which allows you to fit 550cc sti pinks or 565 cc hawk blues.
I went for nismo 550cc side feed injectors ,which are Nissan injectors but the fit into phase1 (v1/v2) or phase 1.5 (v3/v4) fuel rails with "phase adapters". They plug into the stock Subaru injector plug by just filing a tab off .
Just beware of cheap copies and aware that it will need to have the fuelling map adjusted by a mapper straight away
