Air Filter for BRZ
Has anyone else on here had an issue with the air filter before? Barely pumps out any air at all when I put the air con on for some reason. Is there a DIY fix for this? Thanks guys.
First thing I would do is check your cabin filter, if it's clogged that could be the source of your issues
  • 3 years later...
check also the compressor the might be there. Update us for what you will see!
