Oil level check
Can anyone explain why the oil level on my Outback has to be checked exactly after five minutes after switching off. I do this every time without really knowing the reason apart from it says so in the handbook!
I don't know why exactly 5 mins, but you usually wait to allow oil to return to the sump.
Hth
Loud pipes save lives
Yes I realize that but it says not to wait any longer than five minutes because you will get a false reading
Is it the bit that says
'oil level should not be check for at least 5 minutes after shutting engine off, see section 3 of the owners manual for more information.'
I have no idea of the exact reason they wouldn't want you to check it after 5, it could possibly be todo with heat soak from other engine components at a guess.
Sorry I couldn't be of more use
Extract from handbook......For diesel engine models make sure to check engine oil level 5 mins after engine stops . Waiting any longer will prevent accurate oil measurement....page 11.20...When I check in accordance with book its ok if I wait say 10 mins the level rises. There must be a reason but I don't know what  it  is.
might it be to do with the baffled sump ?
I'm not sure what that means. I've asked a Subaru garage here in Spain but they don't  seem to know.
I'm sticking with heat soak into the oil causing it to expand and giving you a false reading
