Car bogging down
My car started bogging down so I hooked up the code reader it said cam shaft sensor. I replaced it started it back up and it was still doing the same thing and still throwing the same code so I had someone look at it and then they said it jumped time. Any ideas?
Get wiring diagrams and check harness visually and with multimeter, if all in spec ideally want put a scope on that and check signals and timing correlational .
Visually checking cam belt with top covers pulled could be wise, you may see belt overly loose (tensioner bad perhaps)
