Subaru Impreza 1995 import
Having issues with my temperature gauge it is reading red before I even start the car
it has had new water pump and genuine thermostat everything was fine for a couple of months after this
I then parked the car up for 3 weeks
got in it and started it and the gauge went straight to red I have now changed both coolant sensors on the crossover pipe
any help would be really appreciated
thank you
The sensor with the single wire plug is for the dash the one with a multi wire plug is for the ECU.
You could try unplugging the single wire dash sensor and see if the gauge still reads max .this might indicate a fault with wiring or dash connector if it still rises straight away 😉
Hi buddy thank you for the reply I have done this this morning and the gauge reads nothing when that wire is removed??
Thanks 🙏
Yeah it was new and genuine I even retested it with the old one still does the same I am baffled 😯
If your sure the sensor is ok there's only the engine loom ,harness and clocks left to check .
Maybe try checking the multi plug (by the battery) and the dash plug is plugged in and making good contact , same with the engine loom earths.
You could try tracing the wire from the sensor plug to the multi plug near the battery .
Test this for a break in, with a multimeter , then do the same from multi plug to the back of the dash .
Not sure how to test the clock gauge other than test fitting another set of clocks .
Thankyou very much for your help I shall try this over the weekend
