Overheating Issue
HI all,
I have a SG5 Sti that has started to overheat after about 10 minutes. Wondering. If anyone has any ideas?
I have checked the coolant and all fine, also no bubbles and can't see it leaking from the exhaust pipe.
The fans seem to come on and at that point the revs drop.
No custard visable in the engine or oil cap.
Steam comes from the black pipe which connects to the radiator once its hot.
When the temp rises going up hill if I lift off the gas the temp drops down about a quarter of a dial very quickly.
Wondering if anyone has any ideas or if it's a common thing. I've seafched the net but nothing.
This is the pipe that steam comes out from if that helps
The larger one behind the little one
You should not be seeing steam. The cooling system keeps the coolant from boiling by keeping it under pressure. Your losing that pressure if you seeing steam from that hose. Fix the leak.
Thanks for all the comments, just to update the thread. It was a cracked radiator, all sorted now 👍
Ok that makes sense. Glad you posted your solution.
