How hard is it to put an Auto Engine in a manual car?
I got a BH5 manual with blow turbo engine,  can I take the engine off an auto turbo and put it in it instead?
Apart from remove the torque converter and replace it with flywheel, is there any problem with the sensors?
you should be able to change the loom from your old engine straight over incl sensors so your ECU should not get upset
