Hi everyone I have a 2006 2.5ltr hawkeye I have had a a few weeks just noticed a few issues.
When the headlights are on , Fuel is low etc nothing lights up on the dashboard but when you start the cars all the lights in the dash appear ok.
When cold it have a strong smell of fuel for a few minutes.
The boot in the passenger side is wet through
Any help on the above points would be appreciated
"When the headlights are on , Fuel is low etc nothing lights up on the dashboard but when you start the cars all the lights in the dash appear ok."
Is that the light behind the speedo etc? Or centre console?
"When cold it have a strong smell of fuel for a few minutes."
Doesn't sound abnormal - they run at higher RPM for a few mins until warmed so smell a little stronger
"The boot in the passenger side is wet through"
A) Check the rubber seal that lines the boot, might have perished over time
B) Check under where the spoiler is mounted, the spoiler has thin strips of foam material between the spoiler and bootlid that can perish over time and let water in. This will then make its way through the bolt holes
C) Are you parking on a slope at all? Try parking the other way
Further to the boot leak issue, check right down where the scissor jack is stored to make sure the water has not pooled up there too.
Thanks Jamina for the reply
The centre console does light up very when the lights are on but very dim it has now headlamp on like I have had in my other cars is this normal
The boot leak I will follow your points above ,
Cheers
Should come on when lights are switched to sidelight or dipped or mains.
attached it the brightness of mine after replacing the bulbs, I have literally just had to do this as 2 out of the 4 bulbs went at the same time.
Yours will differ from mine as I have pre facelift centre console.
gives you an idea though.
There is not a headlights on icon on the dash for my Hawkeye. It is in the user manual. Only high beam. The only clue lights are on is the dials get back light.
oh I see what your asking now - no don’t think blob has a light in the dash for that either.
As said the back light just comes on
Low fuel has a little orange dot in the fuel gauge. You have go quite low to get it to go on.
