Tuning my 2005 Subaru Impreza GDA
Good day lads,
proud owner of a 2005 Subaru wrx GDA
owned the car for about 2 years now.
recently decided I’m going to start tuning it
These are the part I’ve already bought...
*VF48 turbo
*Sti front mount intercooler.
*Sti pink injectors.
*Down pipe & 3” exhaust to Apexi bore.
*Process West Cold Air Intake 72mm w/ K&N Filter.
*Subaru Fuel Filter - Under Bonnet.
*Raceworks 265LPH In Tank Fuel Pump Subaru.
*PERRIN 2.4" TURBO INLET HOSE
Looking for some feed back, what do you guys think of my set up ?
would you recommend anything else that I’ve missed ?
look forward to hearing from you
thanks
Id definetely add an uppipe to this list mate Even a catless sti one will be better and a 3 port boost solenoid maybe all that looks ok as long as you have a remap planned as soon as you have fitted these parts. Be careful you dont push too much power through your 5 speed gearbox, general opinion is its fine for 350bhp max but bear in mind your transmission is getting old now good luck find a good mapper and you should be have a pretty good result from your upgrades.
Yeah sorry missed that part, I Havnt yet purchased a uppipe but planning on doing that this week.
whats the benefits of a 3 port boost solenoid ??
yeah it will be going in for a custom remap as soon as all the parts have been fitted
I’ve already installed a heavy duty clutch,
thanks for you’re feed back hoping to aim for the 290-300 whp, I will update the thread when I have some results
The 3 port just gives better control over the boost for the mapper i dont think its essential however, it was recommended to me to have one fitted before mapping my car. Good luck mate 👍
As above they do give better control over boost when mapping and for the comparative cost well worth the investment
