BATTERY DISCONECT SOUNDS ALARM
Hi Guys,
New to the Impreza WRX. I want to work on the car with the battery disconected, but i disconected the negative terminal and the alarm went off.
Is there a way to disconect the battery on these without this issue? Bonet was obviously up. Standard factory alarm with one button on the fob.
Ive done some research and i cant find a straight forward answer.
Thanks in advance
Key out of ignition! When you disconnect the battery, if the alarm sounds try silencing it using the remote button?
Thanks for your reply. Yes key was out of the ignition, and the fob doesn't respond if the battery negative is off... There must be a straight forward way to do it without !Removed! the neighbours off!? 😳
Does the fob work normally? Do you have the alarm pin? If not Subaru should be able to supply it, assuming a previous owner didn't change the pin.
Yes the fob works normally. Yes i have a pin sticker! Can the alarm be disabled? I see the legacy alarm can on youtube...
