abs warning light
hi guys I have a 2008 impreza hatchback and just changed the front drivers side wheel bearing but thought could get away with not changing the abs sensor as it was working okay but now the abs light hill start light and anti skid light I have got the sensors to fit any other things i should check thanks.
The abs ring is integral to the bearing so no way that could be fitted incorrectly - Def right bearing I am assuming? The abs sensor can be fitted only one way and the plug is quite robust so you couldn't have disconnected it unintentionally. ARB sensor is on other side of car soooooo I dont think there is anything else to look at
Hi thanks for that just to clarify I have not fitted the new abs sensors as i thought i could get away with using the old ones but have the new sensors will be fitting them this weekend thanks . micky
