engine management light on
hi guys Is there any way to put out engine management light out without code reader. every thing was okay till last weekend when I changed drivers side wheel bearing and had to disconnect abs sensor now the engine management light and the hill assist traction control and abs warning lights stay on thought I could get away with leaving old sensors in have new sensors to be fitted tomorrow Saturday been looking online and seen a few posts saying disconnect battery or take fuse out of E.C.U does this work. Thanks Micky
Battery trick only works on some models.
If the sensors are being swapped tomorrow then I'd wait till after and just get whoever swaps them to.pluf in and clear the fault codes.
