1987 XT Turbo Coupe what have I taken on?
Well I bought this a couple of months ago having not been run for around 3 years.
Soon found out why it hadn't been run.
side2.thumb.jpg.c582b8d26843d52d3dd5818c883f17da.jpg564585277_s-l1600(2).thumb.jpg.ce99d038f87c0bdfe91cf9bff08a6a55.jpgIMG_1927.JPG.b0362e0428dae739b853090109bae0cb.JPGIMG_1928.JPG.fdb57a60c2cd117f3c0a349c1e3e71eb.JPG
So out came the engine and found the issue, a freeze plug had popped.
EA582495-1B52-4117-AA1A-49495169CC2C.thumb.JPG.c3a4acc8cb265ca5d9eba4d8ca41ff9b.JPGIMG_2043.PNG.8d896fc7b1d6fb7a2e1c537236cba4c8.PNG
Decided that I'd reuse it with sealant and do a pressure test of the cooling system but the waterpump seal had gone and I'm still waiting for a new pump to arrive from Japan.
So after replacing the cam, crank, sump, exhaust, turbo seals and gaskets and a little bit of tarting up I decided to put it back in a fire it up.
IMG_2042.JPG.e4bb2086c145a408d72c6c529dd47e3c.JPGIMG_2150.thumb.JPG.c90b533611b866bc7fda36e8ff8b14af.JPGIMG_2194.thumb.JPG.3c00fb07482907db7f92ff030530530d.JPG
So new battery, fuel filter, plugs, oil and filter I turned the key.
But I wasn't getting any joy from the fuel pump as it wasn't getting sufficient voltage.
So I connected a battery charger to it and voila
