Back firering and no power
I have a 1999 subaru impreza that will back firer when u try to accelerate has a check engine light for knock sensor but that has been changed any ideas will help
I'd have thought more likely to be Cam or crank sensor.
I do have a knock sensor code don't know if that will cause these problems
Replace the knock sensor then.
I have one on order but the one in the car only 6 months old
No it all still the same apart from a wastegate gasket
I haven't changed anything apart from draining all the fuel as it was sitting for 12 months
