Posted
I had to get some work done for an exhaust leak to pass the MOT. Just checking Subaru's prices for the three main parts I found:-
1. Cat section - £2574 +VAT
2. Mid section - £325 +VAT
3. Back box - 577 +VAT
or £4171 inc if you wanted the lot - obviously gold plated!!
The garage mentioned that you could weld in a cat from another manufacturer - has anyone tried this and what did you use?
Posted
Yes I saw the same when my RX needed an exhaust - Went for the cobra stainless cat back, lifetime guarantee and a lot cheaper
Posted
They don't look like they do one for a 2010 MY n/a hatchback with a single o/s outlet or was yours a custom one?
Posted
see
 Whilst i didn't have to replace the CAT, the cat back system i had made and fitted is still doing its job, a long drive from Norfolk its true but could well be worth considering.
Posted
No I used the catback for a WRX - it is the same layout with single exit you just need a different mesh ring for the seal
You will need a 60mm ring not a 66mmm that comes with the exhaust
  • 3 years later...
Posted
Bit late to the party don't suppose you could link a 60mm mesh ring for me or can I take one off the stock exhaust
Cheers
Register a new account
Sign in
