Anyone tried these from Halfords or know if any good. Or could you recommend some ultra bright bulbs that doesn't involve a full halogen kit?
Sorted.  I was actually advised to use these ones. The ones I put up initially are only a whiter light but these ones produce a brighter light.
Never tried Halfords own and haven't a clue who makes them, but had several sets of Phillips Extremes and Osram NIghtbreakers is various cars, plus Osram Truckmates in an artic with well known poor beam patterns, all have been long lived with better light output.
Well after wasting money buying the new bulbs I bought are actually for the high beam. The dipped beam bulbs are a sealed LED unit on the 2014+ Models so I would have to replace the whole headlight unit.  What a rip off!!!
I thought yours would be the HID setup for dipped main beam not LED?
I use these guys and have gone with the 20Twenty LED product for a coupel of years now, found the higher brightness halogens were genrating a lot of heat and a slight voltage fluctuation caused them to blow
https://www.autobulbsdirect.co.uk/subaru-impreza-saloon-hid-xenon-2014-2015-64.html
Yeah, When I called Proven Subaru he even thought mine would be HID but he did a check and said I did have the led ones. Would cost me about 600 per headlight to replace.
  • 8 months later...
If you're looking for brighter bulbs, I would recommend you to try LEDs, I replaced my headlights with auxito H7 led bulbs a month ago, so far they work quite good,  they are much brighter than the halogens, the vision is so clear at night, really do a very good job of Illuminating the road further away.
  • 4 weeks later...
Hi following on from this i have Outback 3.0 RN 2008 model. looking to replace LO beam with LED bulbs but struggling to find anything here in the UK , found Auxito in US only.
anyone help at all please
  • 10 months later...
 If you're aiming for superior brightness, LEDs are the way to go. I personally experienced a remarkable difference after upgrading to the D4S P32D-5 LED Cool White Headlight Conversion Kit. These LEDs are a league above halogens, offering exceptional clarity during night drives and brilliantly illuminating even the farthest roads. You're in for a treat, as I've got the exact page URL for you 😉
https://xenons4u.co.uk/d4s-p32d-5-led-6000k-cool-white-headlight-conversion-kit.html
