1992 Subaru SVX Build - Project KIIT
An initial thread to track progress for current 6-speed manual swap, along with some other general re-commission work.
  • 3 months later...
A bit of a catch up.....
Car as it arrived
Here we go....
Its been sat for a while, lots of rusty parts and a few oil leaks but body work seems good underneath
Airbox and battery out ahead of prep for engine pull
Manifold off
Alternator, Aircon pump and pipework off - Aircon will not be going back on
Headlights and centre grill out. Aftermarket oil cooler removed as well, as there will be a 6 speed manual transmission going in no need for that to go back on. Radiator had a leak so that will be replaced.
Bumper removed
aftermarket exhaust not in too bad shape but mounting bracketry all rusty
Flex joint broken hence meaty sound when driving 🙂
System removed
Rear end
Heavy calipers will be replaced with newage alloy / brembo items
R160 rear diff with a slight leak, R180 diff will be going in to match the 6 speed box
The rest looks dry and a little rusty - Have read many stories of classic owners and battles with these bolts...
This liberal use of underseal wouldnt be hiding anything now would it..????
R180 vs R160 diff, quite the size difference
Test fit of the R180
catching the rear subframe exhaust mount bracket
Diff to subframe cross bracket hitting the diff casing
Underseal liberally coated but only a little surface rust to be addressed, fuel lines will need that rust sorting as well
Rear brake lines have been replaced at some point but not the tidiest job
Further stripping the rear subframe, think those bushes are a bit suspect
Prep for bush removal
crossmember bush removal
Arms bush removal
Dash removal to get access for clutch pedal installation
Oh damn - that loom is going right where the clutch pedal needs to be....
best get the rest out then as we will need to reroute that
Actually putting somethng back on - door speaker wire upgrade, tidy up the aftermarket central locking installation and repair to the sleeve
old (blue and red) vs new
new central locking 5 core cable in the sleeve as well
loom wrap to ensure sealed
5 core routed nicely, following existing wire path
Ready for replacement speakers
And sleeve back in place
